I just replaced my water pump today. I suspected based on the noise, leakage, and steam that I needed a new pump. I did all four hoses at the same time. I applied RTV to the pump gasket before wrenching it in.
Then I started my car after re-filling the coolant, and did not notice the previous squeal. However, when I parked my car again, I was again leaking coolant. I seems to be leaking from a position near the center of the block, though I can't tell from how high up. This was the same leak I had before I removed the old pump.
I also noticed that the "low oil" light came on - this is the first time I've ever had that light come on. Not sure if that was related or not, but I thought it was odd.
And to top it all off, the pump I removed that I thought was bad turns fine by hand. It looks like I might have pulled a working pump and ended up with a problem the same as before.
I'm stumped now on what to do next. Is this just an issue of the pump not being tightened enough, or is there anything else I can do to control the leak?
