i have a set of stock pullies from when i put on my underdrives pullies... i have no idea if they will work since your car is an '84 and mine is a '91... but they're yours if you need em
i have a set of stock pullies from when i put on my underdrives pullies... i have no idea if they will work since your car is an '84 and mine is a '91... but they're yours if you need em![]()
Let us know right away! ..... Wait! You said you were taking the day off and not even looking at teh Pearl today!Awsome! Mucho thanks! I'll compare 'em to mine and see what I come up with...![]()
Sure wish I had a spare belt (that wasn't shredded) that I could throw on there to see if it would keep hold of the belt or if it would try to throw it off there again. Can't afford to play the "$30 a try" gamble game with new belts, because there's no warranty on those things.
). Last weekend I had fixed the pulley alignment issue by threading in four double-ended studs (a-la Chevy water pumps) and putting two flat washers on each one to move the water pump pulley forward about 1/8" to make it line up. Drove around a whole bunch today, no more fraying of the front edge of the belt, and no more catastrophic belt-shredding. Only cost me about $5 to fix this mess (cost of the new pulley studs and nuts), since I had a couple of stock-sized belts stashed in my closet;
are you going to paint the dash black or red?
have you checked the speedo gear in the tranny? it could be betting worn down and have a few missing teeth.![]()
Sucks because until I get this thing working consistently, I can't ever figure up my gas mileage. No speedo reading = no miles on the trip odometer.Dave, Has the book I sent you been any help with the car?
Looking real nice Dave.
You need to find an SVO or 86Gt steering wheel for it.
looking good buddy, definitely a good choice going with the black.
seeing threads like this really makes me feel bad for not getting out there and working on my pile.
Ugh! Damn Dave I threw away an 89 wheel just a couple weeks ago
Car looks great though Mang
I kinda liked it before but as you been working on it it is really looking like a great four eye
Havent seen a shaft style radio in a LONG time![]()
My fault this time, apparently two washers behind each stud moved the pulley too far forward, so this time it frayed/shredded the belt on the back side instead of the front. Simple fix, just pulled one washer off each of the studs and tossed on another spare belt. Been DD'ing the car all week without and problems from that, so I finally decided to put a NEW belt on there (the spare I had was all cracked with age and kind of iffy) and all is good.
