roller rockers???
Noobof460
ive got a 460. imagine that? anyways ive got a stock bottom end other than a 268 voodoo cam and matching lifters and my heads are stock but theyre ported and have dual edelbrock valve springs. along with my high rise weiland stealth intake. Its not bad but enough for some fun and to be different. My question is while i have the motor apart should i go ahead and add roller rockers and upgrade my push rods. or would it even be worth it on a mild build like mine??? by the way it is goin in a 91 fastback. any info or opinions would be appreciated! and its a internally balanced 75ish engine :shrug:
dont worry with it check ur old rockers for excessive wear and any damages and roll with it a guy who invented a type of head (cant rember the name at the moment) told me if ur not over a 700 lift on ur cam its a waist of time and ur money. just something else to cause problems. trust me been there and done that. the only reasone u would need to swap to roller rockers is if u changed ur valve hieght.(thats where i ran in to my problem with roller rockers) i have a buddy with a dodge avenger putting 950+ rwhp and uses the original bolt down style rockers. hes ran the car for 5 years not one problem out of the rockers.
The reason you go for roller rockers is because there is less friction. Less friction means more power. How much is to be gained is under speculation.
