Hey guys, I just put an aftermarket pioneer cd player in my 89 gt, I used a schosch plug in harness, I have everything connected but the sound wont come through the speakers. The car doesnt have an amp and I tried the speakers with the amp wires hooked up and disconnected, the speakers work fine with the tape player. Any help is greatly appreciated. Thanks
The factory speaker wires in a Fox are 16awg which is fine for 75 wrms. If the car gets the alt whine then its from a couple different things. Poor ground is one. I always run a seperate 10-12 awg ground wire for decks and secure it to the floor or dash board cross bracing. The other way is in an amplified system. If your RCA wires run next to power wires then they can pick it up too. When running amp wires you should have the power wires on one side of the car and the signal wires on the other side. Twisted pair RCAs help with that alot too
