mine died. i bought the replacement kit from LMR. is the replacement pretty much straight forward? or is there a write up i should read?
thanks guys
Joel
thanks guys
Joel
Care to share the info on the keyless entry? How involved is the install?Yeah its straight foward using stock replacements (drill out a big rivet and remove a rod) ...however I went the Parts Express route and added keyless entry while I was at it, been installed for 4 years now. All of it cost less than the stock replacements and only took a few hours of my time to install. But like previously mentioned Jrichker has an awesome write-up for those unfimilair with Mustang wiring or wiring in general.
PM'd you.Care to share the info on the keyless entry? How involved is the install? Where did you get the kit to do this? Thanks
soo i have the new actuators, they came in the mail today. so they pretty much just slide off the rivet and slide the new ones on and re attatch everything? or did i totally miss something
that was my plan but when i got into the door i noticed that the actuator had fallen out of the bracket and was just hanging by the rod that it connects to the door lock with. the new actuators came with a bunch of different attatchments ( im assuming theyre different in some cars) i found the one that looks like my stock one so im good there, however i dont get which order i put everything back. being that i have to reconnect the plug, get the actuator in the bracket and attatch the actuator to the door lock. any ideas?
I just did the Jrichker method and I couldnt be happier.
still no luck....i attatched the hardware to the door lock and the bushings into the bracket, i cant slip the actuator into the bracket without detaching it from the door lock.![]()
