on bbk shortys. driver side went in from the bottom and i needed to disconnect the steering shaft to make it easier. the pass side goes in from the top with the filter, maf, and inlet tube removed.. i didn't need to jack the engine or anything else
Good Luck
I got my BBK equal length to go in through the top on the driver side by unbolting the A/C compressor so that I could move it slightly out of the way. Along with removing the upper intake and valve covers this gave me just enough wiggle room to accomplish the install.on bbk shortys. driver side went in from the bottom and i needed to disconnect the steering shaft to make it easier. the pass side goes in from the top with the filter, maf, and inlet tube removed.. i didn't need to jack the engine or anything else
Yeah, I'm sure it was, but I didn't want to remove the steering shaft.That's alot more work than just jacking the car up and sliding them in from the bottom. I can have an H pipe off in about 5 minutes.
