94 gt shorty headers install help
There will be 8 bolts on each side connecting the head to the header, also two bolts connecting the header to the H or X pipe remove all these bolts and the headers should come right off, installing the new headers are the reverse put bolts back in....ect. But make sure you replace your header gaskets and you use a razor blade to scrape any gasket material from the heads so you dont have any future leaks.
on bbk shortys. driver side went in from the bottom and i needed to disconnect the steering shaft to make it easier. the pass side goes in from the top with the filter, maf, and inlet tube removed.. i didn't need to jack the engine or anything else
okay thanks...thats what i was worrying about, i just wanted to know what all needed to be removed for the swap....
but once again thanks everyone! very helpful:nice:
Reactions: Tootall281
If they're single flange headers, work your way from the inside out when tightening them, or you may have some exhaust leaks. Put the two end bolts in loosely and typically the header gasket has slotted holes at the ends, so you can hang it on those bolts while getting the rest in by hand. Other than that, the biggest issue is fighting with the cramped space.
Like was said ... start with the end bolts first :nice:
When the threads catch ... hand turn ONLY another 1 turn
then
Do the same with all the others
You gotta giggle the header around to get them started :)
and
Get to that ... one turn
The idea is to have them all loose enough so you can go the next step
Run all the inside bolts down to where they are close to touching the flange
Now do the same for the outside bolts
Tighten them all
Besure to use some lock washers or some kind of bolt locking device ;)
Again ... you wanna be able to wiggle the header around so you can
ensure you don't cross thread the bolts :Word:
Have Fun :banana: Good Luck :D
Grady
And... I just discoverd that BBK shorties allow use of the factory header bolts! The factory bolts don't usually back out so they make a great choice, sure they're ugly and rusty looking, but I'd rather look at rusty bolts than have to keep tightening shiny new bolts!
You'll still have to go back and tighten the bolts again after a few warm up periods, but that's the case anytime you install new gaskets regardless of the header/bolt combo!
I got my BBK equal length to go in through the top on the driver side by unbolting the A/C compressor so that I could move it slightly out of the way. Along with removing the upper intake and valve covers this gave me just enough wiggle room to accomplish the install.
