- Jun 16, 2005
- 85
- 0
- 0
I have a running 351 cleveland 2bbl out of a 73 rideau 500 and was wondering if anyone knows what kind of compression that motor would have? (low I know) and if I put open chamber 4 bbl heads on this motor what would I have for compression? I would most likely cam it at the same time. would this be worth it or should I just build a proper bottom end? I am on a budget and a bit of a time crunch. thanks for taking the time.
+2 on your memory failing you. Quench heads are what you want for ping resistence. The quench portion of the head tends to put out the fires of detonation. I built a 400 with milled open chamber heads and with only a 9.7 to 1 comp ratio, it wanted only 93 octane fuel to control the ping where a quench headed 390 with a 10.25 to 1 ratio gladly accepted 89 octane fuel.
