Ok i adjusted my rockers a year ago when installing them. Randomly 3 days ago i go to a friends house about 30mi from home. Car drives fine there. I leave to come home and notice the car ticking. Get it home and pull the valve covers the next day to find a few Probe shaft rockers with a little too much play. Adjustment nut and all bolts were tight. I adjust all rockers on BOTH sides AGAIN. Ticking went away!!!
Now i notice the car feels like it has a slight hesitation almost like a misfire. I change plugs and check the wires and cap again which are less than 6 months old. All is fine. Scanned for codes and there are none. But as i was scanning for codes the ticking came back. I'm damn sure the rocker itself didn't loosen up.
I also noticed that at idle i don't have enough vacuum for the brakes to properly function.
Oil pressure at idle is 50psi.
I do know how to properly adjust rockers. I'm guessing my lifters failed but when i started the motor up after adjusting oil came up out the lifter like it was supposed to. Theres no excessive play in the needle bearings of the rockers either.
What would cause me to keep adjusting the rockers that aren't getting loose and also give me low vacuum.
I've put about 20k on the motor mostly easy miles below 3500rpm
Would a failed hyd. lifter still pump push oil threw the push rod?
The low brake problem started when the ticking did.
Chris
Chris
