DIY: Solid Steering Shaft? Interesting......
SRT Handz
I tripped & fell down and cut myself & got blood
Oct 10, 2004
941
23
La Mirada, CA
www.srtmotorsports.com
I am curious to see if anyone has done this....
Everyone know that the stock mustang lower rack joint on the steering shaft sucks ass. It makes the steering feel horrible and you loose response over time. So owners are forces to replace them sooner or later...i know i have.
Many of you know about the MM Solid steering shaft upgrade and how good it feels...
Maximum Motorsports :: The Leader In Mustang Performance Suspension
But Many people (Including Myself) are turned off by the cost of the MM part at $250. No doubt, the MM part is amazing, but when you can pick-up a low milage shaft off ebay for $20 as a replacement.
Since the weak spot is that damn rubber rag joint, then what if we could just replace the rag joint with another piece....maybe something out of Aluminum.
Well, i was reading other forums and noticed that BMW owners do the same thing because they have the stupid rubber joint. This Dude replaced his rag joint with a Aluminum unit. I also was reading that some E36 BMW owners even use a Hockey Puck.
Do you guys think this can be done on a Mustang 96-04? If that is possible that i might try it very soon....
Stock Z3 Shaft
Aluminum unit
E36 With Hockey Puck Replacement
I thought about that too, why hasn't anyone made a solid replacement for mustang rag joints?
The aluminum looks like a good idea... but a hockey puck? I don't think it was designed for high temps; like under the hood of a car or steering control for that matter.
I wouldn't trust that homemade POS for a second... If & when I upgrade, I will just spring for the MM shaft... Money well spent IMO...
How is this a Homemade POS? I mean it is literally taking the stock Steering Shaft (OEM Ford), which is a very strong Unit, and replacing the weakest link (a Rubber Bushing) with a stronger piece (aluminum or Pre-Impregnated Urethane).
So are you saying that you trust some squishy rubber over Aluminum or Poly Urethane?
I can tell you from experience, that once the rubber bushing starts degrading and becoming loose the steering on out cars goes scary numb. I dont think this will ever happen with aluminum or Pre-Impregnated Urethane.
I was referring to the hockey puck method. The aluminum one actually looks good....
But whats so bad about a hockey puck.
Since i noticed this i have been looking all over other forums and found out some things.
Hockey pucks are strong. They take 100MPH hits to a wall. They are made out of Pre-Impregnated Urethane. VW guys used them as Motor mounts and off road guys use them for lift kits.
you dont think a hockey puck is strong than a little rubber?
I have wondered this myself. I have had to replace them in two previous Stangs of mine, Sure the wheel will dance a bit more in your hand but the feed back and responsivness would be well worth it IMHO.
If I could get a chunk of aluminum like that and drill it out myself then I would do it! Better then dropping $250 on the MM piece. Thats really the last suspension/handeling mod I would have left though :rlaugh:
I guess it just seems hokee to me... I guess I am a firm believer in do things right the 1st time, not to mention the steering of your car is depending on it... If it works than, sweet....
When I saw this thread I thought it was a great idea so I built an aluminum one this weekend and installed it. There is a noticable difference in the steering responce. I will report back on how it works out. If I can get my camera to work I will post a couple of pictures.
On another note while I was working on the steering shft I found that my steering rack is leaking. Does anyone know where I can buy a 2000 Cobra R rack?
No, the rag joint has nothing to do with safety in an accident. Our steering shafts will collapse like a police baton if they are subject to sufficient longitudinal forces in order to prevent the driver from being impaled. However, the rag joint does not perform this function.
The rag joint is there to isolate the steering wheel from every single bump and undulation in the road's surface. Performance enthusiasts like us prefer a crisp steering feel, but the secretary with a V6 Mustang would prefer a smoother road feel, and the only reason Mustangs are still around is because of people like her, so that's who Ford builds its cars to satisfy.
I think the concern with using a hockey puck, or at least my concern, would be the repeated and sustained exposure to underhood temperatures and the urethane breaking down. If they're made with an acrylic urethane, it'll begin breaking down around 160-170° F. Being right next to header primary tubes, I'd be afraid to take that chance.
Thanks for the info :nice:
can you post pics ?? planning on doing it
Over 10 yr old thread I doubt you'll get a reply.....
The hockey puck or aluminum has no flex the u joint and “rag joint” can flex for some misalignment with movement and vibrations. Rebuilding the joint sounds like a better idea to me for a longer lasting vehicle.
Delrin should stand up better than a hockey puck if you are doing it anyway.
