Intake Vac Line Questions Need HELP FOR THE AM!
Adam95GT
2,564
Burlington, NJ
where do the lines from these ports in the intake manifold go:
What about these in the drivers side of the bay:
And these on the lower...
anyone know or have a diagram??? its the only thing keeping my upper off...:mad:
I can't find my vacum diagram, so ill do my best with some pics...
these two,
will go here:
In that nipple that you see there without anything connected goes a smaller diameter "softer" line, that comes from the canister on the passenger side. (blue arrow on picture below)
The red arrowis for the big line in this pic, and the green for the small one.
Best i could do with paint, and using a combo of you pics and my own car
EDIT: Damn, you beat me to the punch, o well
Where it says not sure, thats actually the line supply for the HVAC controls, it goed into the FW right by the Air conditioning tubes, in the rubber grommet that surrounds the tubes
I dont know how the Fox style cars are set up, maybe they pull the vac from the bottom of the mani also??
Thanks guys... i think that second one that you said for the brake is for the cruise i think.... That one side of the manifold that you labled PCV has a plug in it... should i move that to where you said to plug under the manifold?
SO i see that the fpr connects to this fitting... which i think i have...
Where does the line off the back of that fitting go to? and y is that one side blocked off?
I did find these for a fox:
Also that vac line that goes to where the AC comes through the fire wall is that just for AC or the HVAC??? i welded up that hole and pushed the vac line back in to the car.
here correct??
PM if needing clarification. I can check the same diagram/page at which you're looking and see if something makes sense.
The stuff Joel put up on SBFT is pretty good (best online diagrams I've seen).
Once again thanks for the help. I think my problem is knowing exactly what each little thing is named i know what everything looks like but not what it is called:nonono: im working on it but my knowledge is still a little weak.
Doesn't really matter where on the manifold you connect the vacuums to. The only vacuum that connects before the throttlebody plate is the valve cover breather. Wether the vacuum under the intake is 3/8" or 1/4" is doesn't matter. But obviously you wouldn't put a 3/8" hose on a 1/4" barb.
here correct??
The Big line from that T goes over to the vaccum tree by the Brake booster, the one on the back, in that picture, goes to the FPR, and the one on the top, that looks like it is block off, is actually the vac source for the emissions **** hidden underneath the pass. side fender.
That line that goes through your now welded hole, is for all the HVAC controls, mainly the vent door changer
I took some more pics from diff angles
ok i put that 3 prong vac tree under the manifold and ran that big hose that is bound to the HVAC controlls to the big connector. then the 2 small ones i ran the FPR and the EGR to. I also reconnected the One that goes to the brakes to the vac tree... as well as PCV hoses which are rock solid i think i need new ones.... :mad: i might call iut an early day fiddling with header fitment and vac sucks:rlaugh:
You dont have the EGR connected to manifold vacuum, do you? It can only receive the line coming from the EGR solenoid.
