You are referring to fuel pressure? How fast is it bleeding off?
In 10-20 seconds it will bleed down to 10psi and hold there for a bit.
I retorqued the rocker arms at about 15 lbs for now. I have the correct spark plugs in now and it still wouldn't idle above 500, it shook the whole car, and it required a bit of throttle.
I got out and looked and just to get it started I had to move the distributor all the way clockwise. I am guessing it's a tooth off, or the fuel pressure is leaning the motor way out.
I'm going to restab the dizzy and if that doesn't work I'll have to get the fuel rails worked on. I am now thinking it's NOT the rocker arms as my neighbor thought. I'm thinking it's timing and/or fuel pressure.
Mmmmmm.........beeeeeer.
