I haven't posted here much lately as I've been busy on a major build.
I bought my 07 GT coupe two years ago and did a bunch of cosmetic mods right out of the gate. Last year I installed the Whipple HO at 10psi and upped the fun factor a bunch. After burning up the stock clutch, I decided to take the car to the next level and did a full forged stroker build, 6-speed conversion, and increased the boost to 16psi with a Steeda 10-rib blower drive. We're still tweaking the tune a bit to improve driveability but she has a really wicked nasty heart now.
The project as it currently stands (with pics and video) is summarized below:
Performance Data
Custom Tuned by Matthew at Tecmotion on Mustang Chassis Dyno
HP: 535 RWHP
Torque: 511 ft-lbs
Specifications/Modifications
Engine
Livernois 298ci stroker forged shortblock - 9.1:1 compression
Livernois Stage III CNC ported heads with SS/Inconel oversized valves
Livernois high performance valve spring kit
Livernois custom valve grind
ARP main and head studs
Comp Cams XFI SPR Stage II blower grind cams
Livernois cam phasor limiters
60 lb/hr fuel injectors
MMR billet fuel rails with braided steel lines
FRPP oil pump
Whipple monoblade throttle body
Custom ported Whipple inlet elbow
Diablosport Mafia MAF extender
Steeda polished Whipple 10-rib blower drive - 16psi pulley
Prothane Bullet motor mounts
8-bolt SFI Steel flywheel
Brisk HT0 sparkplugs gapped at 0.032
Pyrometer installed in #5 primary
Intake air temperature sensor relocated to #6 runner
Dual GT Fuel Pumps
Exhaust
Kooks longtube headers
Stage 8 locking header bolts
Kooks x-pipe with high flow cats
FRPP stingers and tips
Driveline
McLeod Street Twin dual disk clutch
McLeod adjustable slave cylinder
Tremec TR6060 6-speed transmission
FRPP (Hurst) short throw shifter
GT500 transmission crossmember
Steeda aluminum 1-piece GT500 driveshaft
Hurst shift handle
stock 3.31 rear gears
Suspension & Brakes
Ground Force lowering springs (1.5" drop all around)
Steeda billet lower control arms
Steeda adjustable panhard bar
Steeda front control arm bushings
Tokico D-spec adjustables shocks/struts with remote rear adjusters
Baer Pro-Plus front brakes - 14" two-piece rotors with red 6-piston calipers
Carroll Shelby CS66 Anthracite Wheels
- 20" x 10" Rear
- 20" x 9" Front
Hankook Ventus Sport K104 Tires
- 275/35 ZR20 Rear
- 255/35 ZR20 Front
Appearance
Exterior
Custom painted stripes - HP white over Vista blue
CDC Front Chin Spoiler - colour matched & striped
Roush Rear Spoiler - colour matched
Agent 47 Retro mirrors - colour matched
Window trim - colour matched
CDC Sequential Tail Lights
CDC Hood Struts
Flat black shorty antenna
Side and rear window tint
Side scoops
Quarter window louvers
Street Scene black chrome centre-fog upper grille
Street Scene Bback chrome lower grille
Scott Drake billet hood pins
Custom Sequential Brake/Turn Signals in Hood Scoop
Red powder-coated brake calipers
Alberta Vanity Plate
Horns relocated
Blacked out and detailed behind front grille
Engine Bay
Polished supercharger and snout
Hand polished water crossover
Hand polished valve covers
Scott Drake underhood caps and billet strut caps
Rad cover and extensions - colour matched
Interior
Centre stack and steering wheel LED's changed from green to blue
Ford ambient lighting kit
Action Artistry chrome speaker grille rings
Action Artistry chrome cup holder bezel
Action Artistry chrome brake handle grip
Escort 9500ix Passport radar detector - hardwired
Magden M1b. performance computer - hardwired
Speed of Sound A-Pillar triple pod
Raptor shift light
Autometer Cobalt vac/boost, fuel press, and wideband AFR, and EGT gauges
Roush Vent Pod
Audio/Video/Navigation
Shaker 1000 base system
Pioneer Avic F90BT head unit with Bluetooth, voice recognition, Ipod interface, NAV/DVD, XM
Custom video switch for Magden input
Custom splash screen
History
When I first saw the S197's I knew that I had to have one. I didn't really start looking until the late summer of 2007. After looking around for a bit, I started dealing on an '07 red vert with a tan top. Before I could complete the deal, my wife decided that we needed to go on a family shopping trip to Seattle and after a day or so of wandering the malls, I managed to sneek off and found myself at Harris Ford in Lynnwood Washington. For some reason, this particular vista blue coupe really caught my eye and before the afternoon was out it was mine. The original exterior mods and paint were done at AutoFX in Tacoma, Washington and the lowering springs, shifter, exhaust, and wheels/tires were done by the dealership. My first significant drive in the car was the cruise across Washington, Idaho, Montana, and Alberta - all the way back to Calgary in some of the most beautiful weather and scenery. Quite a way to fall in love with a car.
The May 2008 long weekend saw the installation of the supercharger and gauges. The line locks followed later in the summer. In the fall of '08 a few passes on the dragstrip finished off the stock clutch and the build plans for the winter commenced. The new drivetrain, suspension, brakes, and stereo meds were installed in May/June of '09. The build went very well with a few minor hiccups.
My plan is that this will be a very nasty street car with tastefully selected styling. The car is a summer daily driver with occasional drag strip passes. I have yet to try road course or autocross but might try those as well.
Upcoming Mods (underway - to be completed by July'09)
FRPP 3.73 gears
FRPP GT500 carbon fibre trac-loc clutches
FRPP differential girdle
Steeda adjustable upper control arm
Steeda performance upper control arm bracket
Rad cover stripes (need to be painted)
Fresh chin spoiler
Rear valence repaint
Future mods (next winter)
Dark blue carpet
White leather upholstery with dark blue stitching
White leather headliner and accents with dark blue stitching
Upgraded amps and speakers
White leather trunk treatment
Custom hood underside (yet to be determined)
Custom CAI intake tube - my stock
Interior video mount
Drag wheels & ET Streets
Front skinnies
Additional Pics
Videos
Dyno Pull:
YouTube - Whippled Mustang Dyno Pull
Walkaround at idle:
YouTube - My 2007 Whippled Mustang at idle
Performance Data
HP: 535 RWHP
Torque: 511 ft-lbs
Engine
FRPP oil pump
Dual GT Fuel Pumps
Exhaust
Driveline
Hurst shift handle
Suspension & Brakes
- 20" x 10" Rear
- 20" x 9" Front
- 275/35 ZR20 Rear
- 255/35 ZR20 Front
Appearance
Exterior
CDC Hood Struts
Side scoops
Horns relocated
Engine Bay
Interior
Raptor shift light
Roush Vent Pod
History
FRPP 3.73 gears
Fresh chin spoiler
Dark blue carpet
Front skinnies
Additional Pics
Videos
Dyno Pull:
Walkaround at idle:
