1994 Mustang GT 5.0 will rev above 2650, fuel pump, filter , coil replaced??
This 1994 Mustang Gt is used, it will not rev above 2650 rpm the mechanic said the fuel pump was bad, so we changed the pump and filter and also coil that was checking bad and the fuel regulator was also replaced, the funny part is it starts great and idle fine??
SPOUT connector that is found on the passenger side close to the Air box. The plug is most of the times a GRAY fuse like thing that's inside a connector on a wiring harness. I will check this
Were the codes pulled?
What happens when you hit 2600 RPM?
Does it matter if the motor is hot or cold?
How was it determined that the fuel pump and/or regulator were at fault?
NO, We purchase this mustang used last week, the fuel requlator was all ready changed, the fuel pump was not holding pressure good , or low pressure
