- Jan 17, 2004
- 463
- 0
- 16
OK I know I have heard there are all the same, however I need to make sure before I throw another 200 bucks at a cooling issue.
I currently have my timing cover, brackets, and water pump from my 260 on the new motor. What is the measurement from the engine block mounting surface to the water pump mounting surface. I am trying to determine whether changing the from setup to a 1966 and up from cover may address some of my timing issues.
I have the original from my first 5.0 conversion, nut it is for a efi setup and seems thinner.
When looking at waterpump dimensions I noticed that the newer pumps are about .25 of in inch thicker So I am wondering if the matching timing cover is thinner?
Thanks
Thanks
