- Jul 13, 2009
- 8
- 0
- 1
69 with 351w. How much money roughly am
i saving by doing these things myself as opposed to having an amateur gearhead or a shop do it
For example,if you were to do these on a car for someone,what would you charge?
Compression test.
Remove & rebuild Holley 4bbl carb.
Change both upper ball joints (labor)
Change outer tie rod ends (labor
Install new front rotors (labor)
Check distributor/rotor/internal parts etc are all good.
Install MSD ignition/distributor/coil + neccessary parts that go with it
Compression test.
I am in Bloomingdale and will need some help on some new frame rail/apron's I ordered and have to install.
