I have a 347 from CHP with hydraulic roller cam & valvetrain, 8 qt oil pan, high volume oil pump. CHP suggested I run 20w50, which I did for a while, but when I changed my oil I decided to go with Mobil 1 10w30 synthetic based on input from knowledgable people etc. Using the 10w30, I have very noisy rocker arms and it's driving me nuts (sounds like a handful of marbles rolling around under the valve covers at idle). I'm not sure if they were as noisy using the 20w50 or not, but am probably going to go back to the using 20w50 to find out. I have adjusted the rockers and am starting to wonder if I have lifter problems. So my specific questions are:
- Why would CHP suggest 20w50 oil? Most I talk to about it think it's too heavy/thick, but I'm sure CHP has a reason.
- What are others with a similar build running? Do you have loud rockers?
- Would 20w50 be better for pumping up the lifters and decreasing the amount of bleed down and thus lowering/minimizing the amount of chatter in my rockers?
The noise I get is often compared what's to a sewing machine.
