comp cam XE274H
96SCstang
228
novi, MI
will this cam be too big? i dont want to have to flycut the pistons. i have npi heads so i was told i shouldnt have to degree or anything but i want to ask you guys first. oh, and is this cam decent for a blower setup? i have a lead to get a set of these for cheap but i need to know that they will work on my car without any major problems and be worth the time. i already know i have to do springs, so that is not an issue really. thanks guys. :nice:
Am I just mistaken or is degreeing a cam just verifing that Comp cams gave you the right cam?
96SCstang:
Call the Comp Tech Line and ask the lads if the cams are blower friendly. Call HiTech, too, because they are good guys. I will opine that 274's have too much overlap (intake and exhaust open at the same time) for a supercharger. Yes, you need to degree aftermarket cams. The stock cam gears are sloppy and can result in pretty gross mistiming (e.g.-- "minus 6 on one side and plus 7 on the other" is entirely possible). Sometimes the gears line up perfectly and the result is a "factory freak" that outrun cars that are the same otherwise.
A few phone calls will pay dividends.
HTH,
Chris
