J.Cagle
What would be the best temp and weather conditions for racing? When I get my 14.6 @99mph it was about 90 degrees and humid here in southeast kansas. Would that affect it? Sorry for the dumb questions, but I am a newbie to this.
I didn't realize he was stock, nor did I realize it was already DA corrected. However, Motortrend actually got 13.5 out of it stock.Not wanting to start a war here but 13.5 @104.7 in the 1/4 for a stock mustang, I would like to see it. Maybe down hill.
40th
Don't lower the air pressure in radial tires. The Radial already has a longer foot print than a Bias ply tire, and making the radial have just a little longer foot print doesn't give you anymore traction, what it will do is make your car unstable.
A 8 inch wide tire gets the same traction as a 10 inch wide tire when both have the same compound. I'll prove this to you if you like.
I don't think I'm understanding the meaning of DA correction.I didn't realize he was stock, nor did I realize it was already DA corrected. However, Motortrend actually got 13.5 out of it stock.
OK but what's the elevation in Houston? I bet its lower than 1000 ft.40th
Look, When My daughter ran a 13.7 in my stock 09 mustang GT auto, It was 95 Degrees out side and I would guess close to 100% humidity. It's Huston You Know. All that Da is just BS
You do have a point there since 8" wide Mickey Thompsons will grip better than 10" wide Sumitomos.Traction VS wide tires.
ct07gt
DarkFireGT
You guys are missing one key point. I said as long as the compound is the same. Dragsters run a very sticky compound in the wide slicks, Instead of calling BS, why not just ask to prove it , like I said I would.
Would you care to explain then, why guys with drag radials lower their pressures to ~25 or less psi?40th
When DA correcting, you need to enter in the things that you did, but the purpose of doing so is to correct your 1/4 mile numbers. Your DA corrected ET is 14.05@101MPH.I don't think I'm understanding the meaning of DA correction.
The only thing I corrected was the elevation. My track is at 1002 ft but w/ the 88 degree air, 65* dew point, and 60% humidity, the calculator said 3k feet of DA.
So when people talk about DA, is the ET corrected as well? Because the ET I posted in the subject line is the ET on my timeslip.
We aren't missing the point. We all understand perfectly what you're say. We just all believe that you're wrong. What you are saying is that, let's say for example, a MT ET Street, provides the same amount of traction when it's 7" wide or 12" wide, and furthermore, lowering the air pressure only adds rolling resistance, and provides no additional traction benefit.40th
ct07gt
DarkFireGT
Darkfire
I will just post your entire post
"Yeah, I gotta call BS as well. A larger contact patch will give you more traction. Two tires made of the same compound may have the same traction (per square inch), but the more of that that touches the road at any time, the more traction you have. "
This is just not true, If you knew anything about drag racing you would know this.
He has been warned previously.The tires on a Top Fuel car cause a ton of aerodynamic drag, but they keep on using wide tires, that must be because they don't know what they are doing. By oh9mustang's reasoning, they would be better off using really sticky bicycle tires with 100 psi in them, they would be much lighter and cause less drag. Every thread that he gets involved in he gets in a pissing contest on purpose and insults everyone that responds. And now we wait for the pissed off response and me being called stupid.
I know you like to fight and stir up trouble. You're not winning this one. I'll eat my hat if you can prove to me that a car running a 7" slick with 45PSI will hook up the same or better as if that same car straps on a 10" slick at 20PSI.
So how did you get that number?When DA correcting, you need to enter in the things that you did, but the purpose of doing so is to correct your 1/4 mile numbers. Your DA corrected ET is 14.05@101MPH.
I'm not saying you're wrong, I'm just curious for future reference.
