Hello everyone, new here so this will be my 1st.
I have a 00 gt. According to the door code it has the t-45 trans in it. I have been having an issue with a noise, much similiar to what a spun crank bearing in a motor sounds like. Only the noise is transmission related.. it is only audiable when the car is under load.. mostly when slowing down in lower gears... 1st / 2nd etc. If I give it slight throttle pressure it goes away. If the car is in neutral it's gone and if the clutch is pressed it's gone.. I had a friend tell me he thinks it's the output shaft bearing. Anyone else have any insight on this? I was going to attempt rebuilding it myself. but I want to make sure I'm fixing the right problems. thanks.
