Which Master Cyclinder & Proportioning Valve
Which Master Cylinder should I use running disk front and rear. I just installed 10 1/4" front discs (Scarebird kit) and am still trying to decide on the rear.
Will it be an issue if I change to the new dual bowl master cylinder 1st and prior to changing the rear from drum to disc?
I also need to know what proportioning valve to use, which is the cheapest and where to buy, thanks!!!!!!!!
Master Cylinder
I use a MC from the 1994/95 Cobra and a Baer proportioning valve.
There is a ton of info at Mustang Steve's website.
FYI FORD - MustangSteve's Ford Mustang Forum
You can use the MC with disc/drum just adjust the proportioning valve. once you switch to disc/disc depending on the ones you use you may have to put in a residual pressure valve. Gets kind of complicated but the guys at Master Power Brakes will help you out.
Disc Brake & Brake Conversion Kits, Suspension Kits: Master Brakes.
Here is my setup
http://i98.photobucket.com/albums/l259/rsowell_2006/P9270006.jpg
I forgot to ask this question and no one has mentioned it?
Since I have a single bowl MC, which distribution block should I get? I prefer to by a cheap factory block or pull one from a yard vs. paying $$ for a custom brand block.
I plan to order the SSBC Brake Proportioning Valve after I solve this question, thanks!
