Build an 8.8 axle or swap in a 9 inch
I am having some issues on this topic and was wondering what everyone thought. I have a stock 8.8 axle under my car. With the current setup I have I have already snapped a stock axle shaft off. I just put another stock one in the rearend for now because i already had one. I was just wondering what you guys thought would be the best route to go. Should I build up my 8.8 with tube braces, axles, and spool or should I just switch to a 9 inch and build one of those.
9" is stout for sure :nice:
Then again ... it weighs more than the 8.8 :(
Nice thing about the 9" is you can quickly swap out the punkin
and you got a different ratio ;)
Another thing about going 9" is you will have to deal with
modifying it or buying one already setup to fit your Stang :(
I gotta tell ya ..... Them 9 inchers are tough :Word:
I used to do full on launches at strips all stuck up with VHT
at 5 to 6K with wrinkle wall slicks and never broke nuthin :)
Grady
You can run an 8 second quarter mile on a properly setup 8.8. The 9" has a lot more parasitic drag, and is going to slow you down. Definately go with an 8.8.
Kurt
