Oil burning 5.0, can it be diagnosed without tearing bottom end down?
So my 5.0 burns oil, about a quart every 600 miles. A little background, the car has 70,000 miles on it, compression is excellent on every cylinder, and one spark plug appeared oil fouled. It only seems to smoke on a hard accel or a downshift, this points to rings but it seems wierd that one plug is fouled and all the compression is so good. I was thinking maybe the valve seal on that cylinder, and was hoping to do an H/C/I. :shrug:
Now this is a gamble, because if I set up my H/C/I and it still burns oil, Ill have to tear it down again to rebuild. I'd like to avoid rebuilding if I can, or tearing down the bottom end. Is there a way to spot bottom end issues looking into the bores when the heads are off (any give aways/hints to look for), or do you have to do a full tear down to diagnose?
If it were the seals ............
You'll have new ones when you go with new heads ;)
Grady
That's exactly my point, I'm hoping I can kill 2 birds with one stone with my H/C/I, more power and stopping my oil issue :) That is... if valve seals are the problem
On the contrary, if rings are the problem, I'd hate to bolt up a nice new H/C/I only to still burn oil. Probably burn more oil too with the H/C/I than the stock setup due to higher cylinder pressures :bang:
Thats why I'm hoping theres a way to tell if its rings without pulling the motor.
I had the same dilemma with my old GT, but in my case the engine had a nice clanking noise going on. My mechanic said it was worn crank bearings, but I thought it was something in the valve train. So I tore off the top end to rebuild the heads. I got lucky; I decided to do things the right way and pulled the shortblock out to rebuild it as well. Turns out my crank bearings WERE worn - plenty of brass showing.
You're already partway there, best to rebuild the whole engine and know it's all good.
You could run a wet / dry compression test on the cylinders ...
Compression test dry, then add some motor oil to the cylinders via plugs holes. Any improvement seen would imply rings. #'s the same, valve related....
Correct me if Im wrong, but isn't a wet compression is used to rule out rings vs. valves, IF the dry compression is bad? In my case, all the cylinders fall between 150 and 155 on a dry. If it was rings, wouldn't the dry show it?
Check out my plugs too, the fouled one is from cylinder 3. Im not sure what this means, the cylinder had just as good compression as the others so I figure it MUST be valve related.
No not if all the rings are equally bad. a wet test is the best way to tell... but like i said to be safe id just rering and rebearing the bottom end.
How hard of a job is it to re-ring the stock pistons? There are fairly inexpensive re-ring kits around, can you just drop the pan, unbolt the rods and slide the pistons out the top (with heads off) with the engine still in the car? Is it even worth doing this if I dont pull the engine and bore .030 over?
I believe the stock rods won't fit out of the bores on the top. You'd have to push the rods as far as they will go to the top, take the pistons off and slide the rods out of the bottom....all while working around our bulky k member.
Awwww man, nothing's ever easy with stangs :crazy:
At this point I'm wondering if its worth it to install the H/C/I for this winter's project with the short block as is, if it solves my problem then great :nice:
If not, I'll live with it for the year, then pull the motor and do a rebuild/ mild stroker next winter, the trickflow top end can be used for a 331/347 too (not to mention it's porting potential) :thinking:
Honestly though, with excellent compression accross all 8 and that one fouled plug, I'm thinking it MUST be in the heads (unless I somehow cracked an oil ring in that cylinder, while the compression ring is in tact) :shrug:
Sounds like u have your mind set.
Not sure how many options you will have up there for explorer motors...definitely a good option. I went this route for $500. Although....u could get a block with the same issues.
Have you checked your 150 to 155 psi readings against shop manual specs? If the 155 psi reading falls within spec and you have no cylinder down more that 10% of the others, your good. 70K is not a lot of miles by any means.
Try your test again. Remove All plugs and during each cyl. test, let it
turn over a good 6 or 7 times.
I think your probably seeing valve guide and seal wear.
GT
Thats what I'm thinking, just doesn't make sense to me to have ring issues yet. The owner before me was middle aged and had to get rid of the car for a minivan for his growing family, didn't seem like the kind of guy who beat the car to a pulp, but I guess you never know :shrug:
The explorer thing is attractive, especially because you could replace the cam and springs and have a nice street motor. They aren't common at all up here in Canada though (my friend from washington has one, and I joke about swapping our engines when she's out of town ;) ) plus you can't be sure the "new" engine is any more problem-free than the last without tearing it down, in which case you might as well just do so with your stock engine :crazy:
I'll run a wet compression test and see if my pressures increase, and maybe a leakdown to be sure. Has anyone actually had a case of their oil rings going bad, but their compression rings still in tact? :thinking:
Na, that's not true at all. You generally brake down the rod and piston with a press which you couldn't with it still in the block.
Kurt
Sounds like sound decision making. I think going with an HCI is a good choice. If it doesn't work, you can still re ring the block.
Kurt
