Hey everybody, great site here, glad to be a part of it.
I just bought a 91 GT. It is currently leaking coolant right at the bottom of the water pump. It's a slow leak, maybe a couple drips every 5 minutes of idling. I've read that the waterpump gasket is a pretty common failure point, I plan on replacing the entire water pump and flushing the system, just to be safe. Are there any tips or tricks on this, or are there any good write up threads? A service manual was included with the car (can't remember the brand, has a red LX with it's hood up on the cover), is that a reliable tool to use? I also have an SHO and I know the printed service manual for that car has a few things wrong.
Something else I noticed is that the alternator isn't providing a charge at idle. The voltage will read 12-12.2V at idle put if you just touch the throttle it will jump right to 14V. Alternator belt is tight. Any ideas?
Also, the fuel pump it very loud. When the car is running you can always hear the fuel pump from the back of the car. Is this something I can do? I'm assuming the tank needs to come down, but I'm not sure. I'll keep reading around.
Thanks very much for the help!
Here she is...
Here she is...
