Bulding my first 351 combo help
98gtvert
140
south carolina
Sup guys, Im working on my first 351. Just bought an 85 gt and decided to go the 351 route. Im gonna keep the displacement at 351 ci for a while and i would love to get 350-375 rwhp and keep it streetable. Gotta 750 carb and edelbrock intake with a 544 lift cam. Really need head help lol. Ive read a lot about 5.0 parts make 5.0 power and i found a set of holly heads cheap but only the 170 cc. Which should i go with. got about 1500 to spend. Thanks
With tf heads the cam intake and carb you said i bet you will be closer to 350 RWHP. I did a 351 and it's 40 over AFR 185 58cc heads trick flow r intake flat tappet cam .499/.522 lift 262/268 duration LSA 112 42# injectors 90 mm LMAF 90mm accufab tb,l/t's.Compression at 8:5.1 or so and i put to the wheels 319/339 on a mustang dyno.Going threw a tremac 3550,spec clutch and 4.10 gears.I was told my cam and low compression killed my numbers?peace
john:p
john:p
that low of a compression needs some forced induction. :nice:
here's a newb question.....what determines what the compression will end up being? am i correct in thinking that the higher the compression the higher grade of fuel will be needed? if pump gas is the goal, you need to keep the compression low (say somewhere between 8.5-9.5)?
Compression ratio = (displacement+chamber volume)/chamber volume. Displacement = stroke*pi*(bore/2)^2
Chamber volume = piston dish + cylinder head volume + gasket volume + volume above compression ring + deck volume
Depending on a lot of factors, N/A pump gas engines can run as much as 13:1. Normal N/A street engines are usually in the 9.5-10.5 range. Engines on boost are usually 8.0-9.5 range.
I'm gonna have to disagree here, 12:1 is pushing it when it comes to pump gas, esp. todays pump junk, if you were running anymore than 11.5:1 on a street motor your probly going to be sacrificing timing to get it not to ping.
If your building a pump N/A motor i'd stick with 10-11:1, no more or less either way.
Oh I completely agree. I was saying what the extreme limit was on pump gas, not what would be considered "streetable". 13:1 is possible, I had a buddy that competed in HRM's Pump Gas Drags in a nitrous car that was 13:1.
Of course, that car was always giving them headaches. :D
