I need more speed!
JPstealth
34
Nothern NJ
So my car, for whatever reason, stops at 104mph which actually measures 109 on my GPS but none the less it wont less me pass it.. feels like a limiter. I got tons of power left and it suddenly just feels like my power stops?? :shrug:
I have a predator and try to turn it off but won't let me. I switch both settings to off on the tuner but when I plug it back on in it still reads on?? Am i doing something wrong? All my other settings on it work fine though.
The 4.10s are limiting your top miles per hour because they are making the engine spin faster to achieve a given speed.
What RPM is the engine turning at when you hit the wall on speed?
My car is an automatic and I noticed this problem after I got my 3.73's installed. Took it out to the track and ran it with OVERDRIVE off, and as soon as I hit 100mph - righ on the buzzer - the car would maintain speed but not go any faster. Next run I turned O/D off and I broke through 100 no problem. Next run, turned O/D back on to test the problem and it hit the 100mph wall. If you have an automatic try this. If not, then you're screwed.
We have a long cool down lane at our track and I've blown right thru 110 with no issues. I'm at 6 grand then but I prefer to stay under that. 4.10's should not be limiting your top speed thru the traps in 4th unless you are reaching mid to low 12's.
Make sure your carpet isn't way of the gas pedal. I felt stupid when this happened to me. Can you go back to your stock programming? I would try that and see if that takes care of the problem. I have a X-cal2 and my car will easily blast thru 100mph. Pearl02.
