With the temperature dropping over the last month, i can think of at least 3 reasons.
1. Colder environment means unless you have added air, your tire pressure will be lower, resulting in lost fuel economy through increased rolling resistance
2. Colder environment means air is denser which raises the total aerodynamic drag (not to be confused with your drag co-efficient). Your car has to do more work to push the air out of its path
3. Colder environment, especially in ice and snow, means your tires never reach normal operating temps which further increases their rolling resistances.
4. So many other things that could have happened that I can't think of.
If you are seriously concerned with your fuel mileage, the best way to improve it is to remove as much restriction in both the intake and the exhaust path. Get it tuned and specifically tell the tuner you want an economy tune added. Add tires with lower rolling resistance ratings. On top of that, if you have aftermarket gears over 3.55, adding a 6 gear with a .50 ratio will do worlds for your mpg. Even with everything I have done to my car including the supercharger, I will still get over 30 mpg on the highway. At 200 miles, I am barely under 3/4 of a tank which is still stock size. if you have questions, let me know.
