- Oct 22, 2002
- 3,041
- 2
- 59
A while ago I did some extensive research on what would be the best combo for my application. But the way it goes is that I'm either way to busy to work on my 88 or I don't have the cash. My tax refund is supposed to be direct deposited on the 29th so I decided not to do what I did last year and invest some into my Mustang. So anyways I basically forgot everything that I had learned and have been spending the last few days on here doing some research.
So basically I'm doing the front suspension, upgrading to 5 lug, and upgrading to the 13" cobra brakes all at one time. I already have the QA1 K Member installed and the QA1 a arms that are designed to run SN95 spindles in an 87-93.
Here's the list of things that I think will work best. I just want to make sure 100% that what I have picked out will work. Nothing is worse than buying expensive parts that you can't use!
This is mainly a drag car that can be driven on the street...
1) $150 - Caster / Camber plates
Are these really necessary? Your caster can be 1* off spec and still not wear the tires as long as they are close. Is there a cheaper alternative? Or are they because the tower isn't strong enough?
http://cgi.ebay.com/ebaymotors/QA1-...r_Truck_Parts_Accessories?hash=item563685d56a
2) ~$175 - Coil-over kit
This is where I started to get confused. When I was shopping on Ebay there were a lot of listings that didn't give any description. So I'm just going to guess that this one is one that will work being that it is QA1.
http://cgi.ebay.com/ebaymotors/79-0...r_Truck_Parts_Accessories?hash=item27ae4261d1
3) $220 - Struts
This also confused me. I assumed since I'm running the 94+ spindles, these are the correct struts?
http://cgi.ebay.com/ebaymotors/Lake...r_Truck_Parts_Accessories?hash=item5639031c80
4) ~$100 - 94-98 Spindles
I've seen these listed for $150, but if I can't find any cheaper I'll just go to a pick-n-pull.
5) $100 - 13" '98 Cobra rotors
50 bux each at Advance. I'm cool with that price.
6) $150 - '98 Cobra Calipers
Reman from the parts store ($45 + $30 core).
7) ??? - Caliper Brackets
I couldn't find these listed anywhere. I'll have to check and see if they are still available from Ford... Some guy has a set of calipers and pistons on ebay, but he wants $275 for them. That's way too much for used stuff.
8) $37 - Ceramic Pads
9) $165 - Manual Steering rack
10) $40-$80 Moog outer tie rod ends
I looked up two different tie rods. The ones for an 88 is ES2150RL and the ones for a 95 are ES3184RL. I'm not sure what the difference is between the two so what do I use?
That's basically my check list. I'm not worried about brake lines, boosters, proportioning valves, etc right now. After this I will be taking out the diffy to shorten it, put in a 4 link suspension, weld the torque boxes et cetera. I just want to make sure that I have everything so I can get my front end together and I can move it.
From my estimates it looks like I'm at $1,200.
This is mainly a drag car that can be driven on the street...1) $150 - Caster / Camber plates
3) $220 - Struts
