Since no one really knows how to answer my first questions, here's another for you.
So you're going to use notched pistons... good idea.
You talk about using 1.7 ratio rockers... could be good, could be bad.
What springs are you going to use and where are you from coil bind?
You really need to check your PTV measurement everytime you build an engine.
You need to check coil bind everytime you build an engine.
I will say this; no two engines will be the same. If you take someone's word with your engine... good luck with that.
