- Dec 13, 2009
- 40
- 0
- 0
I have a 67 GTA 4 pinion posi 9 inch under my 68 coupe. Its the factory unit and tonight on my way to work I was driving around a corner and dump the clutch in second gear and lost my posi! It felt as though it was going to break the rear end loose like it usually does but, then it caught traction and just burned one tire off. It drove fine the rest of the night, no noise involved, no smell, no jerking, no nothing but now my posi doesnt work
. The member has been in the car for a full year now and has worked perfectly. I filled the rear end with the proper grease and equa-tork addative. So my questions are:
What do you think happened?
Did I break clutches or burn them?
Is it able of fixing without buying a new unit (can i buy a clutch kit and rebuild existing unit)?
********ALSO CAN YOU GUYS PLEASE TELL ME WHAT THIS FACTORY FORD POSI UNIT WAS CALLED? TRAC-LOK?**********************
My friends dad that drag races alot mentioned I should drain old grease and replace it a few times to flush any debri out and it may start working again.
Please help guys. I atleast would like to know what the name of this unit is called. Any suggestions or comments very welcomed and appreciated.
Thank you!!!
. The member has been in the car for a full year now and has worked perfectly. I filled the rear end with the proper grease and equa-tork addative. So my questions are:What do you think happened?
Thank you!!!
