while i was looking around for a junkyard t5 i came across an opportunity to
pick up (2) TURBOS from a Thunderbird Turbo coupe...i know 1 probly wont work because of its small size and rpm limit. but 2?
1. does anyone know A/R on these...
2. if using both turbos would flow be sufficient to effieciently power a 302
3.what psi to expect
4.any links
4.any links
On a 2.3, the T3 usually spools to 10psi under 2500rpm, 14psi by 2800 rpm or so. On a 5.0 (2.5l per turbo), that might be cut down by 200rpm or so. I know that would give you a nice fat torque band. I personally think twins would be the easiest. You can flip the stock manifolds and the piping isn't bad at all. Just look around for some of the previous builds using T3s.
