When you turn on the lights, temperature gauge goes up 1 1/2 level, this is normal?.
The car gets very hot after 20 minutes, and was changed 2 times the thermostat at this time is no thermostat and gets very hot; with the engine cold and running, took off the radiator cap and water flow (I guess the water pump works).
With the engine running, the car accelerates and the fan clucth also speeds.
Tests are simple, other tests I have to do?
, one electric and one
