Yeah, the comp cams guys are hit or miss. My machinest has a personal contact and his direct extension, so he gets great recommendations. I didn't realize you were using such a small head. First of all, it's the duration and lobe seperation that makes an engine very lopy. Boosted cars usual run a huge lift, and not much overlap to keep the blowthrough down. You'll notice that boosted cars have above average street manners. I think that cam you have is a little to small. My best recommendation for street manner is a Steeda #18. If you really want to make it idle nice, go with a Steeda #19. Steeda designed (or bought that design, I think it was an off the shelf Crane design) specifically to run with the same Edelbrock heads you have. At the time, that was the head they were using. The #19 is the same cam with a 114 lobe sep instead of a 112 lobe sep. If you can run that with a 1.72 rocker it will make up for the 331cid. I ran a #18 with 1.72 rockers my Windsor Jr. heads in my fox body, and it churned out a 12.99 in the quarter. The Edelbrock heads are much better than the Windsor Jr heads by comparison. My foxbody loped a little, but it was my daily driver, and had very reasonable street manners. The car was completely stock tune also, no chip whatsoever. With an SN computer, you can run the #19 with no tuning, but you will most likely have to get a chip to run the #18 with good street manners.
Kurt
Kurt
