the gun metal looks good. what kind of paint are you using?
Very nice, it looks like it came that way!
any updates bud
I believe the brackets are different
Not sure how the PCM will work cause the 94 sensors are way different and there are more of them
Thanks a lot for the bracket/accessory info, and I actually don't mind wiring. Guess I'll see the difference in connectors/mounting locations when I get the harness..First off, the brackets are different, however, as long as you use ALL the accessories and brackets/timing cover/water pump from a Fox you'll be set! The water pump pulley will come really close to the radiator and from what I've read it will negate the use of a thick aftermarket radiator.
Second, of course the fox EEC will work in our cars. People have been doing it forever now. And actually, the Fox has more sensors, namely the BAP sensor.
Jamee, if you are good with wiring and following Ford wiring diagrams I'm quite sure you can pull this off. I'm sure you aren't the first to put a Fox engine/EEC/wiring into a 94/95 Car. You'll just have to figure out how to make all your gauges and such work and how to integrate that older Fox harness into the newer body. Good luck!![]()
I'm not getting those firing orders. Is that the first two cylinders in the firing sequence? I think our cars are 1, 8 as in 1-8-4-5-6-2-7-3.
For headers you can just run a set of stock headers to get you going. Supposedly shorty headers don't offer enough power to fuss around with.
If the dizzy is from a later model truck with a roller cam then yes, it'll work. Otherwise it may be simpler to just buy a reman'd dizzy for a fox (since you're wiring the engine harness as such).
The distributor is from an 87 truck engine.
As for the timing, 1,3,7,2,6,5,4,8 is for HO engines,
1,5,4,2,6,3,7,8 is for non-HO engines. The computer I have, the injectors are set to fire in the HO pattern, so I need a cam that will work with the computer. And I can't rewire the injectors order due to the "computer losing its ability to regulate air/fuel mixture" :fairyfight:
And I'm unsure of where you got that firing order from? I can't find it anywhere![]()
Sorry, I was reading it clockwise and I guess it spins counter clockwise.![]()
