Ok its been awhile since I used the forums, and its been about 5yrs since I had the V6 swapped out for 5L. The local shop can't get their scanner to read the ECM and the BCM is still telling them its a V6 (not sure why they even hooked up to it). The car will just stall out when @ temp and in gear (normally after its been driven for over an hour) however it'll idle all day long (but put in gear and it'll stall after drving 50') then restart and the cycle continues until it won't start, leave it sit 1/2 hr and it'll start and drive fine again for a little while. We had the ignition coil fail on it, and replaced (as it was what caused the glitch in the first place) The local guys don't even want to look at it anymore. You fellows got any ideas?
Much Thanks
Sean
Much Thanks
Sean
