mods, if this is supposed to be in tech, i apologize, feel free to move it
some of you might remember, but i'm picking up an 01 gt front brake setup for my car (dual piston PBR calipers, rotors, spindles) from a co-worker, and just the other day, i found out he has an extra rearend with the brake components on it still (rear is bent so i'm just getting the brake setup). i also pulled the master cylinder from the half of a parts car we just trashed for him at work, just in case i needed it (i have no idea if i do or not).
my question is:
what all do i need to get this stuff to work on my car?
i know about the bumpsteer issue 96-04 spindles cause, so i plan on selling them for a set of 94-95 spindles. what else do i need to get the fronts installed? what kind of brake hoses? can i even use the 01 gt master cylinder? it came off of an ABS car with hydroboost. what brake booster and prop. valve also?
what about the rear? aside from the calipers and rotors, what else can i use off of the 01 gt rearend? what axles should i get? what else will i need that i can't get from the 01 gt rear or my factory rear?
i'm a n00b when it comes to this conversion, so any help is appreciated.
thanks!!
my question is:
thanks!!
All I know is when I had the 94-95's on my black notch those tie rods were way up in the air when they are supposed to be parellel with the LCA's. On Hack Job, (with 96+ spindles) they were parellel with the LCA's. I never liked how my black car was with the 94-95 stuff.
