i will try that when i get home from work, thanks for the tip. it is currently clocked at the 12 o clock position. should i clock the maf while the engine is running?
so you are running a blow through with a stock MAF?
i just tried clocking my maf, i was able to get it to about a 2 o clock position, and it took alittle longer then it did the other days to start idling like ****. it seemed like it was gonna work but after a few minutes idling it started going up and down again until it stalled. i have to make a new cold air with some pipes i have laying around because i dont have much room to clock the maf where its placed right now. if i try to go to either a 3 or 9 position either the sensor, or the bottom of the maf hits the cylinder head.
since the car was still having the problem i did try and do it blow through with the stock sensor. just to c what would happen. the pro m housing is still in my intercooler piping so i just took the stock sensor and through it in the pro m housing. and that doesnt work at all it just stalls right after it fires up. do u think it would work with the stock meter in the stock housing? maybe the pro m meter is too big for the stock sensor??
I'm really confused. There is no way it will work with the stock sensor in the Pro M housing. I thought you had the stock meter in the car housing and all.
The stock meter is going to peg out pretty fast especially in a blow thru setup. What is the whole combo here? Any pics?
heres a vid of it running after clocking the maf, and its idling pretty smoothly.
YouTube - mustang superharged idle
I still need to replace the fpr because i cant adjust my fp any lower then 56psi which is causing the car to run alittle rich. but after i fix that il feel much better about driving the car
