Whats up everyone. Got some tuning issues and wonder if anyone has any advice. First things first, a list of what has been done so far. 1993 lx, block bored .030, crank turned .010. Trick flow track heat combo installed on top end. 190 lph fuel pump. Msd distributor (no box, plug and play). 75mm throttle body. Egr spacer. Cold air intake. Recently had to replace the ECM, just quit on me one day. Put an A9L in the car, came with a hypertech chip installed. I have no idea as to what program has been burned on it. I removed the chip for the time being. So i have been running the stock injectors up until yesterday. I ordered 30 lb Ford Racing injectors and a C&L 76mm MAF. Installed this stuff yesterday, car ran like s@#t. Had to undo everything today just so i could drive it. Im sure it mostly is because of the ecm programming, nowhere near capable to handle those injectors. i was hoping that installing the chip back on to the ecm, might help. It didnt. Car was surging and backfiring through the intake. I tried messing with the timing to no avail. Does anyone know how to find out what program is on a hypertech chip without having to go to a dyno? And any other tuning help with this set up would be much appreciated.
.. C&L are not the way to go
