Need troubleshooting help on 96 Explorer 4.0 V6
Husky44
865
104
74
Tacoma, WA
My kid's Explorer is giving him trouble, and I'm stuck. Any help on where to start looking for this problem would be greatly appreciated:
96 Explorer, 4x4, 4.0 V6, 125k miles, rattling (similar to shaking a can full of ball bearings) from rear of engine. Noise came on suddenly in past few days. Only occurs at idle, when additional load applied by A/C compressor engaging, or PS pump when you crank the wheel all the way to one side. At 1500 RPM, noise goes away. No performance problems today, but last night from a cold start, it would not hold an idle without additional fuel.
No codes on the computer. Any ideas what might be the problem, or where to start looking?
Thanks,
Greg
Just did some research (on my phone so nothing profound) but there seems to be issues with timing chain rattle and carbon build up issues. Also I read something about it happening right after an oilchange. Another post said something about a lifter or pushrod issue
Possible iac valve issue causing low idle and engine shake rattling exhaust or something?
Is the rattling internal? Or can you track it down?
I don't think the rattle is coming from engine shake; I thought about exhaust, but it'd have to be a visible, violent shake to make that much noise.
I can't tell where it is, other than it sounds like it's coming from the back of the block. Other than that, not much help to locate.
I haven't read much about the other 4.0, but I'm sure they would be able to answer your question there, about the noise in the motor. I have a 01 explorer sport 4.0 sohc 4x4 and I have found a wealth of information there.
I'm a member on there too. I was actually gonna suggest checking them out.
I thought it was 3 or 4 but couldn't remember for sure. I knew 1 in the front 2 going front to back. Wasn't sure if there was a rear one or not.
I had a 95 it ran great. When I got the 96 gt I gave the explorer to my parents. They sold it to my one sister. After she had it a couple weeks it started having torque converter/trans issues. They went away I guess on their own. It had like 186k on it when I stopped driving it. It's still going for her.
They are great little suv's.
my 98 explorer rattles at idle on startup, especially cold start up. but its the tc tensioners i believe. i think you are right, 96 4.0's were OHV. 97 up had the option of the 4.0 OHV or the 4.0 SOHC.
sort of a blind guess but have you stethoscoped anything?
good look on finding the issue and hopefully its minor,which im sure it is. those ohv motors are good motors.
Thanks for all the ideas. I haven't found the problem. Tested IAC valve, and it's good (cleaned it anyway since I had it off). No change.
By two days after I posted this, the problem had completely gone away. :shrug:
I'd love to take credit, but I'd reached the point of total surrender. Least it's not a problem (for now)...
