- Apr 19, 2011
- 84
- 0
- 6
Hi all. I seem to be having a little trouble out of my 94GT (bone stock) when I first fire it up for the day.
When I start the car when the motor is cold, it seems to idle ok. But then when you go to put it in reverse, or even 1st gear, it starts choking up and trying to die. It seems to get down to about 600 RPM unless I give it some gas and try and keep the RPM's a little higher. Then of course they shoot up past where they need to be for backing up, or starting off in first gear.
And there is some kind of popping noise coming from the mufflers while all this is going on. Some kind of low pitched, semi-quiet, popping noise. The noise is not rapid or anything, its a little random. Its something like "...poomp... poomp poomp... poomp..." Like its struggling or something. But the weird thing is, once the car warms up, this never happens. Its like the problem just disappears, until the motor gets cold again. Any idea what could be causing this?
There is no gearing on the IAC valve. It's a solenoid activated bellows as far as I can tell. If there is a problem it's with the solenoid and there is nothing that can be cleaned to fix it.
