Oil fill extension
Toms95
Has any seen where I can get a oil fill extension that is push in to valve cover and takes a push in cap? I've seen push in with screw cap but I like the cap I have and don't want to replace it but with the tight area of fuel lines and sparkplug wires, I have a tendency to hit the battery wire on the back of the alt when I pull the cap out. Already put a small arc burn on it :(
Trick Flow® Billet Oil Fill Kits: TFS-51400800 - trickflow.com
Thanks for the info. Not quite what I'm looking for though. While I realize it would be a small tube, you'd think someone would make an extension that you just take out the push in vented cap and add the tube. I should have clarified that a big reason to keep the cap is the venting. That cap is and all the screw ins I've seen are not.
