Tell everybody How you power Shift!!!
well, yes, power shifting isn't good for the drivetrain. If you want to be nice to the car, then let off the gas and take it easy between shifts. But if you want a little quicker time at the track and are willing to accept the eventual repairs, then keep on power shifting. Personally, I've replaced several shift forks and got the tranny rebuilt in the process, as well as some fresh bearings in the rear end. Was worth it though. ;)
Ares, I assume that is prp. Do you go there often?
Yep every saterday. I run in the modified class
This is my second 3650. The original lasted 4 years of track abuse before I messed it up. Still haven't torn it apart to see what exactly. The current one I picked up in Aug or Sept 2008 and has worked pretty good to date.
What year is it from? My 3650 has all the revised parts in it but im still scared to rag on it.
Whenever I have I put my foot on the loud pedal and shift as fast as I can.:p Ive only power shifted a few times in my car and the last couple of times and I found that I miss 3rd gear a lot... Im guessing its time to replace the stock clutch at 97,000 miles... :D
You gotta line lock in that car?
Yes, TCI linlock I have setup between master cylinder and proportioning block. Button on shifter controls linelock/2step.
Current one I think is out of a '01. Was told when I bought it that is was rebuilt at 30k miles and I got it at 60k miles. Put 19k miles on it since. I can say street wise the original 3650 shifted smoother no matter what I was doing. This one is little notchy on the street but has worked near flawlessly at the track.
Broken trans, broken rear housing. I don't think twice about it just let it rip and when it breaks I get out and laugh as I know it was bound to happen.
