Back of a 5.0 intake for temp sending unit? Bad idea
oldfox
234
I have heard that the back of the intake will show a lower temperature than the front. So I tried it to see. Bad idea
Seems that the fluid for the cooling of the engine is only about 1/2 way through the engine and hasn't picked up the heat yet.
I switched the sending unit back and forth just to see
Hissin50 you were right and I was wrong (hate when that happens)
:hail2:
190 in the front = 175 in the rear on a steady highway cruise
Alternate placement for a temp gauge sender:
Revised 24 July 2011 to add better temp sender location description and the necessity to loop the fluid flow through the heater circuit.
How it works:
If you want any kind of operation similar to stock, the ECT/heater feed line is the best place for a temp sender or fan thermo sensor. After all, the computer uses the ECT to pick up data on how warm the engine is. Putting the temp sender in the same line as the ECT is a simple way to get the best possible accuracy at minimum cost and complication.
Some things to keep in mind:
Just be sure that you haven’t blocked the coolant return because of a leaky heater core. For this to work correctly, the coolant needs to flow from the ECT sensor tubing back to the water pump. That means a leaky heater circuit gets looped rather than just plugged up. Join the rubber hoses together with a hose splice from Home Depot rather than plug them up.
Where to put it:
Use the heater feed that comes off the intake manifold that has the ECT sensor in it. Cut the rubber hose that connects the manifold water feed to the heater and splice in a tee adapter for the temp gauge sender. That way you will get the most accurate temp readings since the coolant is always flowing through the heater circuit in a stock car.
Tee adapter info:
Make a pilgrimage to your local hardware or home supply center and get some copper pipe and a tee that fits the temp gauge sender. Solder two pieces of copper pipe onto a copper pipe tee with threads in the tee part. Find the correct brass fitting to match the temp sender threads to the tee fitting.
attachment.php
With both the current 89 LX 5.0 I have and its predecessor, an 89 GT, the temp indicator stayed around "L-A" on the word NORMAL. If repositioning the sender to the passenger side rear location on the intake manifold caused it to run cooler, it might not even make it up to "L".
If you wanted any kind of operation similar to stock, the ECT/heater feed line is the best place for a temp sender. After all, the computer uses the ECT to pick up data on how warm the engine is. Putting the temp sender in the same line as the ECT is a simple way to get the best possible accuracy at minimum cost and complication.
I had drilled and taped two holes in the rear of the intake.
As it turned out I used both of them one for the stock gauge just so i didn't have a dead gauge and with the set up I have now I needed to use the other one for the heater. I hope that I pick up enough heat to keep it warm this fall. But i dont plan on running it in the winter.
The ECT sensor is located in the front of the passenger side lower intake manifold. It normally mounts in the heater feed tubing fitting that is part of the lower intake.
