LarsD's build thread
I've ran the royal purple stuff in my tko since i got it in 2006. I had the shift lug problem in my car and I needed to call tremec to get the replacment parts. I told the tremec rep that I used it in my car and he didn't say anything about so I don't think it would hurt anything to use it.
I thought it was closer to $10 a quart, I'll probably just get the syncomesh then.
Just and FYI Lars- and you proooobably know this already, but.
There was a show on Spike tv, on powerblock. Not sure which one. These fellas put a car on a chassis dyno, and made a few base pulls. They then drained all the fluids,engine, trans, diff, and replaced them with royal purple.
Back on the dyno, picked up something like 11-12 hp.
I don't know if it was BS because they were sponsered by RP, but I was always amazed by that.:shrug:
What fluids were in the car before?
I've seen tests like that before, and sometimes they fail to mention that they also went to a lower weight oil than what was originally in the car. That, and, we've all seen a car vary 10+ hp on consecutive runs, with no tuning or other changes.
That said, I do believe that there is some power to be had with a good synthetic oil, I just think sometimes those dyno tests are a smoke and mirror show, know what I mean?
I've seen these stories before. I do think synthetics are great as I have seen them save engines from disaster, increase fuel mileage, etc. Mostly just want whats best for the trans.
This is also true. I already have Mobil 1 in the diff, as that is some slick stuff.
I need to get out in the garage and get started. It's 115 degrees out there right now. lol
I was going to come in here and make a post asking if you guy think I should chance a 2 year old water pump with about 6K miles on it. Then I got it off the car and saw staining on the weep hole. Could have been when one of the crossover hoses split a couple months ago. Do I really want to risk a new engine to save $40 though? Back to AM I go. How many quarts of that RP you guys think I need?
My shop is a wreck. Half of it is parts waiting to go on the car.
Think I need a new AITS?
Getting there:
The things you have to do to pull and engine by yourself.
Almost out.
Finally. Note, it helps to remember the two lower block plate bolts when trying to separate an engine from a T5, rather then yanking around on it for 20 minutes like a jerkarse wondering wtf is going on.
Getting the trans out took like 10 minutes.
Now I get to start cleaning. Also ran over on the miles for my WRX. So now I gotta go change the oil on it. Then I can shower and relax before work tomorrow.
