Fuel System Q
hoopty5.0
mechanicus terribilis
7,854
6,994
214
SW Houston
I need a little help planning the fuel system for the 408. It needs to be able to support 550 hp with a little room to grow.
Do I need to replace the lines and rails?
What pump is most popular? I read to stay away from external Aeromotives..
Replace the stock tank or just sump it and use it like it like that?
Also can't decide between the Megasquirt or PMS... Looks like many people like the MS though. Thoughts?
Thanks
Collin
I think you will be good with the stock lines, a 255 in the tank and maybe a pusher pump with 42# injectors. Thats what im running, i used it when the car was making 480 at the tires with a supercharger and now im using it with my NA motor. It has worked out great and didnt break the bank.
Id say MS over the PMS. The PMS is a good system, but the megasquirt is 100% standalone, cheaper, and easier to use IMO
if you want to have room to grow id personaly go summped tank magnafuel pump -8 feed lines magnafuel regulator and a -6 return.
Both are great points. I had heard that stock lines are good to 500 hp (crank) and the obvious difference in the two is price.
Maybe I'd just start with the 255 in tank and see how it works. Can always upgrade if I need more. If it goes lean at the top end I'll know where to start trouble shooting at least.
As far as the megasquirt goes, does it eliminate the need for dyno tuning? I know there are a few guys in the area who are good with it.
Stock lines are good for around 500rwhp with boost, so with a NA motor, that number will go up.
I think trying to keep the stock lines is a good idea, there not hurting anything and fuel systems are pretty expensive.
MS dosent exactly eliminate the need for dyno tuning, what i did was get the WOT done on the dyno and we also worked on the driveability. The WOT part of the tune was good when i left the dyno, but the drivability still needed some work, so i did most of that myself and got the car driving really well using the VE analyze part of tuner studio. The software basically tunes the car for you if you set it up right. The dyno is just a tool to use to tune the car. Its really hard to do it on the street, especially if you are trying to drive and tune the car at the same time, so the dyno is a good safe place to start
