9 91foxbod50 Member Sep 26, 2007 486 0 16 Jan 31, 2012 #1 Jan 31, 2012 #1 Has anyone ever had luck with keeping your stock hood? I'd imagine using vert mounts and avoiding the 1 inch spacer might work. But Im also thinking about cutting the hood and covering it with a scoop.
aar0s Founding Member Dec 20, 1998 1,015 55 69 Jan 31, 2012 #2 Jan 31, 2012 #2 What kind of intake you planing on running that would require cutting a hole in the hood?
ID89GT 10 Year Member May 26, 2008 1,659 18 49 Spokane Valley, WA Jan 31, 2012 #4 Jan 31, 2012 #4 If its just a 302 I don't see why you would have a problem. Usually only run into hood problems with 351ws and carb applications..
wythors Get off my lawn!!! Founding Member May 17, 2000 2,277 35 69 C Addle Jan 31, 2012 #5 Jan 31, 2012 #5 ID89GT said: If its just a 302 I don't see why you would have a problem. Usually only run into hood problems with 351ws and carb applications.. Click to expand... Ditto that. There will be no clearance issues with an intake swap on a 5.o.
9 91foxbod50 Member Sep 26, 2007 486 0 16 Jan 31, 2012 #6 Jan 31, 2012 #6 I've had clearance problems with a trickflow upper and lower
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,307 18,013 224 Massachusetts Jan 31, 2012 #7 Jan 31, 2012 #7 Cobra intake with 1/2" spacer clears fine here Sent from my iPhone 4S using Tapatalk
NIKwoaC 中國製造 15 Year Member Oct 31, 2006 5,525 943 214 Chengdu Province Feb 1, 2012 #8 Feb 1, 2012 #8 91foxbod50 said: I've had clearance problems with a trickflow upper and lower Click to expand... Which one? I've got the long-runner R and I have no hood clearance issues.
jdb3rd Member Apr 28, 2005 166 3 19 edgewater MD Feb 2, 2012 #9 Feb 2, 2012 #9 I have a trick flow with a 3/8" spacer and a stock hood cleared it
