Need some Advice?
MY 85 GT
1,852
208
104
New Jersey
Ok i have an 87 GT still Speed density.Running 19# injectors and FMU.Mods in Sig..Can ran a [email protected] sure there was alot left...i dont have any type of tune ..I was running rich with the Meth..and timing is locked...im Basically doing a backyard tune..lol..Now i was going turbo.But then i said wait Maybe i will do a Trickflow top end kit...H/C/I go to MAF conversion,42# injectors,340 lph fuel and a tune...Would this put me in the 12's maybe even the 11's?....Do you think this is the way to do it?..Get some nice Head gaskets,ARP studs...do it right...What type of HP will i make?...I just want a fast street car...Dont get me wrong the car is quick now Just want it Faster...LOL....Any help would be great Thanks...
One of the threads on here right now is about a fella with a Vortech low boost kit (5-6psi), stock bottom end, heads, and cam with a GT40 intake, long tubes, 73mm MAF, 30lb injectors and he's making 343/411...pretty good for a stock cammed/headed car. If you were to put on better H/C/I plus boost, the car would of course increase power. As long as you tune it correctly, yes-you can hit 11s. Theoretically speaking, it only takes about 300-350rwhp to get into the 11s with a full weight hatch or coupe-vert is another matter and the driver has very much to do with it. Suspension and chassis upgrades are in order though, if you wanna run 11s with a vert. If you don't at least have full length subs, and one of those later model 'vert X braces, you're gonna turn that thing in to a tweaked canoe.
That being said, yea, you can put your car into the 11s pretty easily with a supercharger. Just gotta match up the parts correctly, upgrade your suspension, stiffen your chassis, etc. Also, that powerdyne head unit used to be known for snapping belts and toasting bearings. If the bearings fail, the impeller contacts the volute housing and spits little metal pieces into your intake tract. There's a place that used to do upgrades on them so they wouldn't do that, but I don't know if they're still around...928 Motorsports?
Thanks for the reply...My Blower is upgraded by 928 motorsports..Better bearings,Kevlar belt,Upgraded impeller,It makes 10 psi they way it sits now...I was thinking a TF top end Kit with this blower and a tune i should be able to do 11's...Or i was thinking of doing the On3 turbo kit with a set of heads,decent intake,and tune...that should put me close to 11's also..Im confussed on which way to go...lol
Well, there are plenty of directions you can go with it no doubt. But, just map out what your end goal is, and start perusing the threads on here and elsewhere about what people have done to make a full weight 'vert run 11s. Like I mentioned before though (and I'm living it right now because of floorpan and chassis cracks), don't neglect your suspension and chassis...having the power is fun, but if you're not putting it to the ground, it just turns into expensive clouds of tire smoke and sometimes broken parts.
Reactions: GameCock5.0
