Wheel Spacer Vibration
98 Nick
24
San Diego
Hey guys,
I just put two Hubcentric 1" wheel spacers on the rear of my 98 GT today. It looks amazing, but at 65 mph and higer, I get a vibration like the wheels are out of balance. I did the specified torque on the lugs as the directions stated and they seat perfectly flush.
Any idea what is going on?
They look similar to the Eibach's but appear to lack the TUV approval the Eibach's carry which makes me question their quality. Might be worthwhile pulling the wheels and spacers back off and carefully inspecting them for evidence of fretting/movement, distortion, studs coming loose etc. You might also take them to a machine shop and have them checked for trueness, flatness and runout.
That's good advise and what I was thinking. I might just get rid of them and go for the Eibach to be on the safe side. Thanks again!
Out of curiosity, are the washer things that they put on the studs still on there? I only ask cause I have a buddy that put some wheel spacers on his Dakota over those and it caused a bad vibration.
Interestingly enough, they didn't come with washers. That's interesting.
You did remove the rotor retaining tabs (I believe that's what Notch was referring to...)?
The tabs may not be there if the rotors have ever been replaced on the car. Generally speaking they were installed on the assembly line to retain the rotors before the assembly of the brakes and installation of the road wheels.
If the tabs are there definitely remove them before installing the spacers...
