Vert Seatbelts
bsk116
I know, boring subject. Does any one know if I can repair (by cleaning or lubricating) the tension, or lack thereof, in the front belts? Very annoying to keep adjusting the belt while driving. Or should I just order new belts?
Also I'm wondering if vert seat belt kits are the same as coupe/hatchback. I have looked at various vender sites and they don't seem to differentiate between body styles.
I bought a new set from LRS. They worked pretty well. I have never found any for the back though.
Sent from my DROID RAZR using Tapatalk 2
Thanks, so apparently there is no difference between body styles. I'm pretty sure they have the rear sets @ LMR as well, no time to check, off to work.
I know LMR has the rear sets. I just bought a new set for the front. they run about $174 per set. It isn't the cheapest, but what you have to consider is that you are spending that money to try to keep yourself from getting killed in an accident. Is the money saved over relubing your seatbelts worth your life?
