Does Anyone Make A Bolt On And Go Coilover Kit?
See if we can get a few solid answers about the UPR kits here.....
Sharad
Thanks.
We actually offer two options for bolt on coilovers in the Fox Body Mustangs.
One style is the sleeved coilover setup like this:
http://www.uprproducts.com/mustang-rear-coil-over-kit-strange.html
The aluminum sleeve slips over the shocks. We have this setup for Strange, Lakewood, and stock shocks.
The other style setup is what you'd call a true coilover, like this:
http://www.uprproducts.com/mustang-rear-coil-over-kit-springs-shocks-qa1.html
With this setup (like the used QA1s the OP already picked up) the shock body itself is threaded, so the springs are thread directly onto the shocks with the adjusting collars. It's quite nice, but it's more money than the coilovers sleeve style.
Thanks.
Hey Sharad, just want to clarify, it's the same kit for Strange, Lakewood, and stock shocks right? So say if I want to put the kit on stock shocks and upgrade to Strange shocks later on I wont need to buy a new kit correct? COUNT ME IN!!
Reactions: Sharad
well I do want to share that raceland sent me an email that ill post up:
here is my email to raceland/ rokkor:
Comment: Hello,
I've been looking for a set of coilovers for the foxbody mustang (79-93) and was curious if you might have anything in the works. I and many others have noticed a hug gap in the coilover market for the (79-95) mustang market which are basically all the same most kits seem to be slip over systems. and many are looking for a reasonably priced coil over kit for street and light track use.
Thanks in advance,
David Pepiton
there response:
David,
We are actually testing a Mustang kit as we speak. Keep up to date on our progress and pre-order specials by following us (links below). You can also sign up for our newsletter for updates.
Sign up here: http://www.racelandus.com/newsletter
If you should have any further questions, please let me know.
Regards,
Cody Graham
We have a different part number for the Strange and Lakewood. I believe the stock shocks fit the Lakewood kit. I'll PM you my cell number, and if you have more specific questions you can let me know.
Thanks.
Comment: Hello,
Thanks in advance,
David Pepiton
there response:
David,
Regards,
Cody Graham
Coooooool, wonder how much $$$$$$ though.
Hey guys dumb question on the rear coil overs. When you go to coilovers must you keep lower control arms? Or do the lower control arms no longer serve any purpose? I am wondering if I go with rear coilovers if I can sell my upr adjustable lower control arms and springs, and throw my stock lower control arms with no springs on just so that I can keep the sway bar. Or if I will still be benefiting from the upr adjustables.
well if your wanting to reinstall your sway bar then youll need to change it out since they dont look to have anywhere to attach the sway bars too. im sure someone will want those if you decide to sell or heck even trade just keep in mind you will no longer need the spring purch
the rear UPRs will go on the shock like any coil over
the UPR lower arms you have will still serve a purpose since it will hold the axle in location and wont have deflection like the stock stuff does.
You talking about the rear? I know my car doesnt need coilovers, but I want to be able to adjust the height. I am still considering going with weight jackers in the rear, but the price is about the same anyways...
Yea sorry I am talking about the rear. How much are you looking to adjust it? As in just lower the rear of the car? I cut 3/4 of a coil out of stock ones for my car and it sit perfect. Until I put a weight ballast in the trunk so I had to put uncut ones in.
